does my exhaust look to low?
This looks a little low for my likeing. Been underneath & everything looks fine.
Does this look low to you?
Anyway or parts to tuck it up tighter to the bumper?
cable ties round the rubber mount will tighten it up
nice and clean though and no pitting - good job!
My exhaust had an ajustable height rear bracket on the backbox for this problem...does yours??? Or you could try rotating the join between the backbox and the midbox...the join that is roughly under the rear seat area...found that this join rotation does affect the final position abit when I did mine!! B)
Mine was like this, so adjusted the bracket :)
Ha ha cheers fella's. Where would the bracket be? Or is it obviously what the rubber is attached to?
That's possibly the cleanest standard Tip I have ever seen on a Vrs
Not bad for a 7 year old I suppose. Lol.
And a bit of t-cut metal polish now and then. :)
Edited by Fabla
Bump. Just looking at my exhaust tonight and it does look low. Would look so much neater if it were tight to the bumper. Where is this bracket?
Thanks.
Thanks.
Right behind the bumper....get on floor under bumper and look up!!! B)
Couldn't adjust mine. (non adjustable bracket). :(
Bend the Hook coming off the back box "Down"
Today's job sorted! Cheers Lew0. :)
No problem :)
where about you from ?
Hirwaun now. Originally from Merthyr. Still work there though. Where you from?
Just up the road then :)
I'm in pontypridd.
Still cannot adjust the height. Couldn't bend the bar enough.
Had every one got the 3 way rubber piece triangle that holds the exhaust up??
Any other ways of lifting it. It's doing my t!t5 in now looking at.
