Brake Bleeding
Hi all. I know there are some topics discussing brake bleeding but none have answers to my query. I have recently done the following:-
Replaced Master Cylinder
Replaced all disks and pads
Replaced rear brake hoses **flexi to copper pipe**
I have used the Eezibleed method and using the Haynes Manual I bled in the following way:-
Bled the master cylinder and the primary and secondary valves
Bled NSF left bleed valve
Bled OSF right bleed valve
and then I followed the normal procedure:-
Bled clutch bleed valve located on top of the transmission housing
Bled OSR bleed valve
Bled NSR bleed valve
Bled OSF bleed valve
Bled NSF bleed valve
And again to point out I was using the Haynes manual. So whats the problem? Problem is that when I pump the pedal several times it becomes solid and resists just as Haynes suggests it should and then when I start the engine the pedal moves slightly but then still feels spongy. Again pumping the pedal makes it solid and resists but then starts to drop very slowly half way past the clutch and accelerator pedal and then resists.
In general, there is resistance there but it just feels slightly spongy. I know this means there is air in the system still but could there be something I am missing?
The brake system is the IE Mark 20
You probably have air in the ABS module, which was introduced when te master cylinder was replaced. To get it out, you need vagcom or dealer diagnostics, as it cannot be removed using normal methods. It has a built in bleeding procedure.
Seconded.
