reversing sensor faulty?
hey guys,
got a fault with one of the 4 reversing sensors, can you help me out?
When I'm reversing it thinks there's an object behind me so there's the constant beeping if tho there's nothing there.
However, reversing from a cold start it's fine! it's just if i've been driving for more than about 5mins then i want to reverse then there's a problem with the sensor!!
Its reversing sensor just above the exhaust pipe (not sure if that makes a difference or not).
Can you guys suggest anything I can do to fix it?
cheers
Are they factory fitted sensors?
What car is it?
it's a 05 octavia, factory fitted.
currently living with it, but it drives me insane sometimes !
Mind posting an Auto-Scan? :)
I take it you have checked/cleaned the connectors already?
Edited by Theresias
