engine light
Don't know if this the correct place to enter this question,
Has anyone had the management light come on , informing you to change high pressure sensor, which has now been done 4 times, the light still staying on,after 8 months.
Also now a new light has come on ( the coil flashing) 1 week ago this was the turbo waste gate which was replaced , but has now come on again, but no loss of power unlike before?
Does anybody else have any problems with their skoda
Mine is a 2009 superb with 110,000 miles on it
I recently had the coil light flashing, followed by the engine management light - it was the pressure sensor on the DPF replaced under warranty.
Mine is a 2009 Greenline 1.9 - 30,000 miles
Hi, it might be worth getting the glow plugs checked out... if on their way out (in my experience) they don't make the car sound bad but when replaced the car does "suddenly" run notably smoother.... amlost like new :yes:
I'm surprised no-one else has had any suggestions, I'm no mechanic but it sounds like a potential reason for your problem.
Regards
Stef
Regards
Stef
HI
Thanks for input , but Skoda dealer has had the car in about 8 times for the problem. So far changed the pressure sensor 4 times , rewired the loom and then changed the ECU this still has not sorted the problem out.
Regards
Stef
Sounds logical to me too.
Phil
I had the same thing last week, flashing coil, then engine management light. Car drove ok in lower gears but was a bit flat in higher gears. Booked it into my dealer (Progress in Letchworth - good crowd!) who suspected DPF sensor, but it was actually the turbo dump valve. I'd get that checked out if you haven't got it sorted yet.
