Faults with Columbus fitted in 19-CAN, any ideas?
I fitted a Columbus in my pre FL Octavia. Everyting seems to work fine except the controls for the maxidot display. The wiper stalk end button does nothing in Audio or Navigation. I can live without that but when I did a scan the following faults showed up in 19-CAN, 37-Navigation and 56-Radio. Does anyone know if this would be connected to the controls not doing anything or if it's a sign of any other problem? Thanks!
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 220807F1000738
Coding: E9807F0E4002021303
Shop #: WSC 73430 790 00000
VCID: 3041C387DAB3
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 77
Mileage: 42373 km
Time Indication: 0
Date: 2000.00.00
Time: 19:34:49
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 77
Mileage: 42373 km
Time Indication: 0
Date: 2000.00.00
Time: 19:34:49
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3T0 035 680 A HW: 3T0 035 680 A
Component: RNS-MID H03 2764
Revision: AB001001 Serial number: SKZ6Z7K4153059
Coding: 000004000201000000
Shop #: WSC 33361 790 00082
ASAM Dataset: ------------------------- ------
VCID: 2E7DDDFFC087
3 Faults Found:
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 86
Reset counter: 60
Mileage: 42160 km
Time Indication: 0
Date: 2000.00.00
Time: 20:49:15
00856 - Radio Antenna
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 72
Reset counter: 60
Mileage: 42160 km
Time Indication: 0
Date: 2000.00.00
Time: 21:42:52
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 5
Fault Frequency: 98
Reset counter: 100
Mileage: 42160 km
Time Indication: 0
Date: 2000.00.00
Time: 21:52:18
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2E7DDDFFC087
3 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 86
Reset counter: 60
Mileage: 42160 km
Time Indication: 0
Date: 2000.00.00
Time: 20:49:15
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 72
Reset counter: 60
Mileage: 42160 km
Time Indication: 0
Date: 2000.00.00
Time: 21:42:52
Freeze Frame:
Fault Priority: 5
Fault Frequency: 98
Reset counter: 100
Mileage: 42160 km
Time Indication: 0
Date: 2000.00.00
Time: 21:52:18
  • 4 months later...
Some of these are connected to the problems I am having - take a look at this thread and try some of the suggestions there.
You won't get rid of the "00821 - Antenna 2 for radio" unless you fit a second radio aerial (FL Octavias have a second aerial in the rear windscreen demister, I believe).
As the codes say the control module is incorrectly coded.
The issue with the wiper stalk will either be the coding or the firmware.
Some of these codes are from when you swapped the units over.
Clear the fault codes on those modules and see what comes back for a clearer picture.
Have you coded the Columbus so that BAP is disabled?
