breather hose
i get my new breather hose tomorrow from viper performance.i was just wandering how all it will take me to change this part?also what does this breather hose do?my sound like a stupid question but i haven't a clue about cars...
Assuming it is the upper hose with y split shape, it should take no more than 10 mins and suggest fitting proper jubilee clips on aswell once you have removed the old clips.
Will leave the next bit to someone else
Yup Y pipe takes 5 mins just needs new hose clips. Got a viper one on mine and was impressed with it
thanks for the help..
right fitted new top y shaped breather hose,but i'd like to do the under the y shaped 1.but viper performance doesn't do them.so can anyone tell me were i can get 1 from..thanks in advance topnotch..its the 1 thats connects to the bottom branch of the y shaped breather..
Was told that viper do the bottom hose and that it's just not listed, call them m8
  • 8 months later...
I think I may need the Viper Y hose, but what diameter clips do I need and am best getting Mikalor? Thanks!
They're about 20-25mm diameter IIRC so you should be ok with any clips that adjust from 30mm to under 20.
When trying for the lower pipe, try removing the battery. That should give you better access with bigger tools.
