Recycled Air button
Does anyone with a Fabia Estate have a recycle air button instead of air conditioning?
Once the button is switched on what actually happens?
I have never used it so am unsure as to what it is supposed to do. Does it take any power from the battery?
You can switch to the re-cycle button if you are in heavy traffic or a long tunnel, it stops the poluted outside air from being drawn into the cabin and recirculates the air that is already inside the cabin, it's brilliant if you traverse some of the long 21k and more in length tunnels in Europe. It also switches off the Air Con when in use.
DB.
DB.
I don't have air con in the car :(
The one thing I do miss is not having a sunroof.
Its garbage on most cars all it does is steam up the front windows
DB.
It shouldn't switch off the ac when in use.
Agreed, does not switch off AC
