tyre opinions
See I've run those as well, and I think they're dire! Sold the rear two after I wore out the front two.......
Queer aint it
My old man used to swear by them on his old evo4 back in the day
does 205s on the front rub at all? when on coilies? and thats me gonna be running 35mm adapters on front and 25mm rear
If you go really low with those adapters, the front wheels will catch the arch when you hit potholes/larger bumps in road :(
Nope!! Have you seen my old yellow one at all? Coilies brembos twists + a whole shabang more
Posted in one of your threads???
205's all round
yeah ive seen it jase, what adapters were you running? and were your twists 8.5 rears and 7 fronts?
205/40 tyres will give a simular rolling radius as the standard 16" tyres. They are also the size of tyres on the Fabia II vRS.
Jase was running the standard 35mm front / 20mm rear combo.
I also ran the same combo, before purchasing some 25mm adapters for the front to allow some tuck and to avoid the arch clipping.
I don't think Jase would have been able to fit 25mm due to the brembo clearance...
Yes i had to run 35 mm on the front
Mines didnt scrub but i had sensible lows
No point in wrecking the ride for 10% looks imo! I kept mine practical and performance orientated
Knew this one would descend into banter about tyre makes :D
i assume if you went much lower it would have rubbed?
Why would you want to go any lower?
If you want to slam a vrs why didnt you just buy an sdi??
I wouldnt know dont have my crystal ball this morning
not saying i would but just asking.
If you lower any car enough it will rub so id guess yes it would rub
That was mine down at the back only adjuster cups in and front to match... Kw v1's
