problems with boost
had my vrs octavia now for few weeks had it remapped last week
and its started losing boost can hear air spitting when you get to around 3000-4000 revs
sounds like its coming from the left as sounds worse with passenger window down
sometimes it does it and sometimes it doesnt
sorry for putting it in this section
but cant get into the others
any ideas common faults etc
sounds like you have a boost leak some where possibly the factory fitted dump valve(found under the engine cover passenger side) notorious for failing! best bet get your car scanned with vag com see what fault codes come up
Welcome to Briskoda.
Yep sounds like you have a boost leak.
Davy
Hello and Welcome to Briskoda :thumbup:
thanks for replies
have got it booked it monday to go on a smoke machine where they fill the air pipes with smoke
will this find any leaks including if its the dump valve
have been reading up and sounds like it could be as it sounds to be coming from the left
air spluttering sound on and off when boost goes up
if it is the dv whats the best one to get or should i stick to standard
was also thinking of a pipercross or k&n pannel filters but have heard these can cause problems
thx lee
Hi and welcome aboard.
thanks for replies
thx lee
K&N or Pipercross are both good filters tbh, and best off going with a Forge 007p DV :thumbup:
welcome to briskoda
