Rear Door outer Windrow Trim
Hi,
My back passenger door drivers side has a small problem the rubber strip that goes along the window on the outside of the car at the bottom, has started to bubble up and lift up by the door pillar. Is this a easy thing to remove and replace or am I going to have to strip the door dowm. Any advice welcome as it looks horrible and as a temp fix super glue is all I can think of to hold it down, many thanks
If it's the weather strip, It's easily replaced with a degree of care!
I'll look out the P/N for the hatchback if you'd like.
Hi,
Thanks for the reply and yes the part number would be great many thanks
