ENGINE WONT START
HI ALL,
NEW MEMBER SO HOPE YOU GUYS AND GALS CAN HELP.
JUST GOT A OCTAVIA S REG AND ALL WAS WELL TILL LAST FRIDAY IT STOPPED ON THE ROADSIDE,JUST CONKED OUT
AA CAME OUT TRIED TO FIX IT NO JOY.TOOK IT A FRIENDS LOCKUP HE HAD A LOOK AND CAME UP WITH THESE CONCLUSIONS
NO DESIL COMMING THROUGH THE PUMP CHECKED THE THINGY ON THE PUMP NO POWER(RAN A CABLE FROM BATTERY TO IT AND IT CLICKS)
THE BATTERY WAS ONLY HOLDING 11 AND AFTER AN ALL NIGHT CHARGE CONKED OUT AFTER 5 ATTEMPS TO START.
CAN ANY 1 HELP PLEASE
COLIN
You might get flamed for the caps mate but you done the right thing by signing up here , helpful bunch. Hopefully you'll be back on the road in no time. Sounds like the pump might be duff. Whats the history on the car , mileage etc.
X relay fault, I'd guess. Do a search for relay 109 and you'll know more. Basically when it fails the engine will stop and there will not be any relevant fault codes stored. A new relay is around £20 and about 15 minutes to fit.
Yep relay 109 would be my guess too. It's situated under the dash on the drivers side I believe.
