ENGINE WONT START
HI ALL,
NEW MEMBER SO HOPE YOU GUYS AND GALS CAN HELP.
JUST GOT A OCTAVIA S REG AND ALL WAS WELL TILL LAST FRIDAY IT STOPPED ON THE ROADSIDE,JUST CONKED OUT
AA CAME OUT TRIED TO FIX IT NO JOY.TOOK IT A FRIENDS LOCKUP HE HAD A LOOK AND CAME UP WITH THESE CONCLUSIONS
NO DESIL COMMING THROUGH THE PUMP CHECKED THE THINGY ON THE PUMP NO POWER(RAN A CABLE FROM BATTERY TO IT AND IT CLICKS)
THE BATTERY WAS ONLY HOLDING 11 AND AFTER AN ALL NIGHT CHARGE CONKED OUT AFTER 5 ATTEMPS TO START.
CAN ANY 1 HELP PLEASE
COLIN
First off get a new battery, they should be at least 12 volts. Have you tried finding someone with VCDS, the box you plug into the diagnostic socket, to try and find if there is a fault code logged?
IAN
IAN
A healthy battery should show over 13 volts!
As previously suggested VCDS should provide the answer.
All the best and welcome to the forum.
Dave
Also, as it's an S reg you might be better off in the Octy 1 section...
