Parrot Bluetooth Kit
Hi all just wondering if any one has fitted a parrot bluetooth kit model ck 3100 to a 2007 octavia 2
Was told that there is a iso lead that plugs straight to radio wires and then to bluetooth
Spoke to dealer and they told me i will still need a constant live from fusebox with this leed
A frind of mine recently fitted one to focus and it plugged stright in worked no bothers
Any help would be greatly APP
Cheers and Thanks
Yes, you can get a quadlock adapter from halfords for £20
Switched live is what you need though and this is on fuse 19.
iPhone using Tapatalk
What the guy says above. I got a piggyback fuse from eBay and used the windscreen washers fuse to get the power. Mines a 2007 Octavia.
I've just fitted a CK3100 to my 2007 Octavia just last week.
I used a SOT-976 lead from ebay here
I needed to swap the orange and red leads over on the parrot cable, then take a switched live from the fuse box with an inline 5A fuse. I did fit a piggy back connector initially but it stuck out so far I couldn't get the lid of the fuse box back on!
There is very little room behind the stereo but there is room above it if you gently lift out the air vents and storage box.
Many thanks to all for the help
Will let ye know how i get on .
