bad misfire
I have a bad misfire,the engine runs in 3 cilinders,and judders like hell,smells like hell alot of unburned fuel.
No checkengine light in the dash,nothing,went to dealeship and after 2 hours of scratching behind the neck and VAG COM testing the verdict was: inginition module broken,it seems they are not very sure,and I don't trust them.
They said they checked the coils,injectors,wires,body throtle...everything.
I arrived home,and check the coli pack,unmount them...and WTF one of the coils (no 2) is blown,has 2 cracks.It took me less than 5 min to figure.
My question is:
When a coil is blown ,isn't that very easy to see on VAG COM ?a message like "misfire on cyl 2" ??
My biggest concern is both are broken coil and ignition module.
Edited by IulianE
It'll be the coil pack. There is a VAG coilpack recall at the moment so go back to the dealer, & get all 4 replaced for free!
mine are old type 1.8T and not included in the recall....allready been at the dealership
Well, when I checked the thread preview, my immediate reaction was "bad coilpack and/or spark plug".
My question is:
If you have vagcom, you can monitor misfires in measuring blocks 14, 15 and 16 iirc. With it being the old type ignition system though, you will have a module screwed to the airbox lid, and it may be this which has failed. Try a new coilpack and see what it runs like. It could just be the cracks are causing it to short out on the engine block.
I just changed the cracked coil,and the engine is running the same. :(
The only option left is to change the module.
I have to choose between 2 german brands for the electronic module. BERU and HUCO
BERU is 35% more expensive than HUCO ,and I am wondering is it worthing?
Beru is an OEM brand, might be worth going for that one.
After heavy researching I went for the cheap HUCO,many owners who bought HUCO ignition modules have no problem at all.
And besides that this is the VAG list of cars with OEM Huco ignition modules
AUDI 80 2.0
AUDI 80 1.6
VW Multivan
SEAT ALHAMBRA 1996
SEAT CORDOBA 1993-1999
SEAT IBIZA II 1993-1999
VW CORRADO 1991-1995
VW GOLF III 1991-1997
VW GOLF III Cabriolet 1993-1998
VW GOLF III Variant 1993-1999
VW GOLF IV Cabriolet 1998-2002
VW Passat 1990-1996
VW SHARAN 1995
VW TRANSPO RTER IV Box 1990-2003
VW TRANSPO RTER IV Bus 1990-2003
VW TRANSPO RTER IV Flatbed/chassis 1990-2003
VW Polo
VW Vento 1991-1998
Tomorrow at 10 AM I'll pick mine ;)
