fitting forge007 dump valve
anyone local to wolverhampton / dudley who can fit a forge 007 dump valve for me
on a 2004 octavia vrs
as ive had car remapped and still have the standard fitted
as i havent got a clue where to start
also could anyone local have a listen to the whistle i have coming from drivers side and tell me if its normal or not
would travel up to 20 miles
message me with a price plz
It's really simple to do.
Get two new jubilee clips - 25mm ones.
Take engine cover off (4 plastic screws, just turn 90 degrees and they pop up)
Remove factory one-use clips (prise them off carefully with a flat blade screwdriver)
Pull old DV out, stick new DV in.
Tighten clips.
Refit engine cover.
On a related topic, how easy is it to fit the forge silicone hoses and does anyone know if they come with clips?
depends on what hoses you want to fit in particular. turbo inlet pipe can be a bit tricky as it 's very tight space to work in. other pressure hoses are quite easy in my experience.
there used to be a few great guides for hoses fitting on here and on uk-mkivs.
Nice 1. Cheers fellers. Apologies to lee1972 for hijacking his thread
still not got a clue no good with cars i will screw it up
oh well if no local replies tomorrow will take to garage as im no good with cars at all
im only around the corner mate in wolves,but misses lives in upper gornal,i have a forge on mine ur welcome to look at to see where it goes.u can pop round tonite if u want a look mate ill b in after 8.
Edited by phillyctr
thanks have seen where it goes but have no idea where to start
if i mess it up im screwed lol
would you be able to fit it if i paid you
im in sedgley but can bring it down no problem
drop me a text mate i will sort it for you pm ed you my mobile number im only in black heath
a
did it for him last nite mate.
good good all sorted thats what i like to hear
