Trip computer permanently on
After much huffing and puffing (mainly around getting the wires behind the stereo) have finally installed the Parrot MKi9200 kit to the Symphony stereo in my MK1 Fabia VRS
Now everything is working fine, kit/stereo only come on when I turn on the ignition, but have notice the trip computer/mileometer displays are permanently on (tho the fuel/temp gauges tuen off) when the ignition is switched off and keys removed
Any ideas?
Or do they stay on all the time and I've just not noticed before?
Any ideas?
When you say permanently on, have you watched for several minutes after turning off and removing the key. On my vehicle the trip still registers for sveral minutes not actually timed it, this has been the same on my last three Superbs so I assume it is normal.
Seems to be permanent, tho switches back to time display when turn ignition off
The LCD display (mileage, trip) is always on, I guess you have never noticed before.
Thanks, never sat in the car long enough to notice. The Parrot kit is pretty impressive btw
NORMAL OPERATION OF THE CAR....not a fault.......don't panic...well not yet anyway.....you'll soon get real faults....then you PANIC!!! :giggle:
