Steering rack advice
Ive just finished fitting a recon steering rack.
When fitting the track rod ends and sort of tracking it by by eye to parellel position, the end only screwed in about 5-6 turns 10-11 mm in length at each side.
Has it engaged enough thread? Or has the wrong rack been sent?
Edited by Tiberius
mine went on 11 turns each side, few more on the TT tie rods as they are longer. might just be you havent gone on enough. If it says 1J at the start of the PN it should be fine. Think thats right, (1J is mk4 golf)
Didnt you count how many the others came off?
:thumbup:
