help, its packed up again
hello
help
the last time i drove this car it managed to do a massive 3 miles before it broke down and the starter motor went bandit and left me stranded
so i repaired it and left it alone,well alone after that
then i had the amusing idea of using it again LOL, mistake
first was the brake warning check pad light on
the fault was a broken terminal on the nsf caliper so the warning wire wasnt connected.
it managed 400 miles this time , a considerable improvement on the first breakdown but its in speshal needs mode again !
it feels like limp mode but no lights on, no boost and slow to do any thing
the tool im using is a maxi scan
the fault codes are
charge pressure control
positive deviation : p 1557
17965 - 035 01/01
kwp1281
i done the usual brief checks, as was dark,cannot see any vac pipes split, then erased the code and drove a few yards and its still in limp mode
has anyone had this issue and know of a remedy, is it a component or pipe work.... or....
is a 130 tdi a vnt turbo?
charge presure control and n75 sonoid valve , where are they fitted
regards
Edited by strongmanatforrestgym
