Remove plastic surround
does anyone know how to remove the plastic console / surround for the switches on the driver door / handle?
Many thnks,
Chris
taken from Haynes manual.
with the door open remove the insert (rubber bit that you get hold of when you close the door pulls out towards the door card), then use a flat-bladed screwdriver under the trim on the grip handle, and carefully lever the trim towrds the door trim. The grip recess with switches can then be unclipped upwards and removed.
Cheers Bodie!
:thumbup:
