OKADA Plasma Direct Ignition Coils
Anyone know further info about these coils? could they be suitable for Fabia engines?
A revolution in ignition technology!!
The Plasma Direct is the ignition coil with a high power amplifier built in to it.
The Plasma Directs produce 4 times more spark energy than stock coils and also generate an ultra fast multi spark discharge of 10 sparks up to highest RPM.
The spark amperage is increased 100%, allowing the spark to reach many more molecules and therefore accelerate the ignition and combustion process. This is extremely important in forced induction applications but also improves the performance of normally aspirated engines.
The Plasma Direct will increase horsepower and torque throughout the entire rpm range. This upgrade will also reduce fuel consumption. Even the engines with a legendary smoothness will be further refined with the Plasma Direct upgrade. Our Plasma Directs are OBD II compliant.
Installation is easy. Direct bolt-in to the engine, no splicing or cutting into stock wiring, simply replace the stock coils with our Plasma Direct Coils and ready to go!
Plasma Direct is made to a specific application. Please check Application chart to find the correct model for your car.
http://www.okadaprojects.com/usa/products_direct.htm
and an interesting review:
http://www.audizine.com/forum/showthread.php/380485-review-Okada-vs.-OEM-rev-D-coilpacks-Bosch-FR5DTC-vs.-NGK-5238-spark-plugs?p=5560088#post5560088
On e-bay:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170668734025&viewitem=&sspagename=STRK%3AMEWAX%3AIT
I have used similar products before from Taiwan.
It increased the response and torque a little bit, felt sharper, didnt improve mpg by much.
One things for sure, it aint worth that much money, you can pick up clones of them for much cheaper.
All in all, i think its junk and probably not suitable for turbo charged euro cars, more for japanese rice rockets.
having a laugh at that price!!!
I will say though that alot of the misfire issues with the 1.4TSI are caused by poor spark, which then coats the injectors with crap, ruining the spray pattern which makes combustion worse, causing more misfires.......
so better spark plugs, coil packs are on my list of todo's, but no way would i pay that price
I' ve sent an email to the European distributor to give me more info on the matter and if these are possible to be fitted on Fabias.
If I go ahead with this I will report back.
