OEM Head Unit
Hi,
Can someone please post a pic of their oem head unit im lookin for one off a fabia vrs but i presume octys will us the same.
Octy head unit it different, not the same shape and they have a tape headunit and 6 -CD.
Ok thanks, well in that case can anyone post a pic of a fabia vRS OEM head unit. Unless other fabia models have it, its the one with the single slot cd player.
I have one upstairs.......
here you go
To fill in the gap, the HU will be the same shape as these ones, only these are OEM tape decks from a Fabia. As I say, same shape though. :D
side shot this is why you need the blanking plate
Thanks very much doer1 and devonutopia for those pics! :thumbup:
On a connected note, can one extract the OEM radio if one doesn't have the keys to do it? All I've found in the archive so far is http://www.briskoda.net/forums/showthread.php?t=19092 which suggests keys are required. And how does one get the button blanks above the unit out.
Reason - I'm considering fitting a Parrot CK3100 (including installing the head unit through a button blank) and want to avoid the
Cut up an old credit card to the required thickness to fit in the removal slots.
You will need to push it in sufficiently to release the catch.
(The stiffer the credit card the better).
This works every time for me if I dont have the right keys.
Hope this helps
Dougal
I just went into the dealer and they used the Skoda keys 20 sec's
Thanks for the responses - always thought there'd be a use for my stack of old AA cards one day... :)
The linked thread is interesting too - still trying to find a route to get my Road Angel power supply through the fascia...
On a connected note' date=' can one extract the OEM radio if one doesn't have the keys to do it? All I've found in the archive so far is [/color']http://www.briskoda.net/forums/showthread.php?t=19092 which suggests keys are required. And how does one get the button blanks above the unit out.
Kenwood removal keys work. They cost about
