shudder when starting octavia
hi all my name is luke and i have owned my octavia for four years. it has 130k on it and had a engine rebuild. at times when i start the car bit is very hard and rough but at other times it is smooth and ok
any suggestions on this matter?
thanks luke
Temp sender, maybe sending wonky signals down the line to ecu
i.e. it's thinks it's hot when cold starting so doesn't add enough fuel
If it's shaking so bad that it feels like it's running on three cylinders, then you may have a bad injector.
