Steering wheel fault code
Hi everyone,
does anyone have smiler Steering wheel fault code in 2008 Octavia II , auto scan to my 2008 Octavia II with Ross tech HEX-USB-CAN cable:
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0002042
Shop #: WSC 73430 790 00000
VCID: 8103150DA199
Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
00883 - Ignition Switch (D) Terminal S
012 - Electrical Fault in Circuit - Intermittent
Edited by senthilk7
The S contact is built into the ignition switch and senses that the key has been inserted. It does things like turn the radio off and switch the courtesy light on when the key is removed. The code is self explainatory, in that an intermittent fault has been logged for it. Clear the fault and see if it returns.
Ignition Switch on the way out? Wouldn't be the first one. :(
