Workshop manual / parts / Windows 7 64bit
Ok guys / gals
anyone out there found a manual etc that will work on Windows 7 64 bit Home Premium - all I've looked at are for 32 bit or professional versions or is there a dead simple fix for this to run on 64bit
Have looked at the link in another string to a Russian parts listing which seems ok if a bit of a fag
any leads welcomed!!
You could tell Windows 7 to run this particular program as/in 32 bit mode. From memory, right click the .exe, select Compatibility tab and choose appropriate mode. Hope this works?
Highly unlikely to work with the Windows 7 64bit even in 32bit mode. It isn't the program itself that has the problem but the hardlock drivers which cannot be so easily overcome. Assuming you have the 32 bit software you are better off dual booting or using a free bit of virtual software like Windows virtual PC.
You lost me when you said "64bit" so I'm going to be absolutely no use at all.
Would be interested if anyone finds a manual that will work, out of the box, on a home pc though.
