buzzing/vibrating boost gauge needle
had a boost gauge fitted the other day
the t-piece is meant to be anti buzzing
but at high boost vibrates and buzzes
any fix or could it be a faulty gauge
its a swoosh emay item number 160629446283
I don't have a solution for you mate but would like to see a pic of it installed if you have one...
Cheap gauge maybe?
Where do you have it plumbed into?
into the inlet manifold
emailed seller said i need to buy a anti-buzz t-piece
the listing said it came with one but came with a normal 1 waiting for reply from them
What mm vac line you running as if it's to big that can cause it to buzz.
the one that came with it from new
the place i had it from are posting a no-buzz t-peice out monday
as it was meant to have one with it
will see if that solves it
