Just had mine serviced
oil and filter
Gearbox oil change, ask them to check and change as its now done 170,000 it was 1 Lr short so just as well, so in went 2lrs of fresh after draining.
screen wash and other consumables
new bulb for number plate
labour
Grand total £88.27 is that cheap??
Errr, yes.
The mechanic is VW trained and has set up on his own, as the main dealer who he worked for over 15 years closed 3 months ago, but he is not yet VAT registered
That's a bargain price :thumbup:
I go to a local VAG specialist and he charges £100 for that service. That's in London though :doh:
Just a quick run through
Oil filter £5.94
5w30 total semi synth oil 4.3 lr £6.50Lr £27.95
transmission oil £12.16 £6.08 Lr
consumables £3.99
bulb £0.73
labour £25 per hour 1.5 hours £37.50 :thumbup:
Why has he used a semi synthetic?
I change the oil every 10.000 and that's what I have always used
Is it Vag spec oil? Ie 505.00?
Yes possibly, I normally top it up with the same 5 30 from halfords
I always thought it should be fully synth in the diesels? its what i used in my Caddy (same engine as your car)
Yes, should be fully synth.
The 5w30 504/507 VAG spec Halfords stuff is fully synth.
I would check for certain with him, as it won't be particularly good for your engine and turbo, particularly with the mileage already covered.
i bet he services a lot of fords lol!
Ive just had my cambelt & water pump changed along with a full service. Including oil, filter, air filter, fuel filter & pollen filter.
Brakes were checked too. Car was washed before it was given back to me and all for £300.
I've used this mechanic for years now, and he really knows his stuff. Prior to the service, I asked him if I should supply the oil, as I'm a fussy buggah!
His reply, "It's OK, I'll use the proper PD VW approved oil." Not only did he, he supplied me with a litre of top up oil should I need it!
My argument is that there are some excellent independent mechanics out there. A lot better than the main dealers in my opinion and for a fraction of the price.
