changing brake discs and pads
Hello guys, i am currently trying to restore my vrs 01
to its former glory :) , its a little beaten up :(
One of the remaining problem is that i need to change both rear
brake discs and pads and im hoping to be able to skip out on the
work shop cost on this problem.
Now i have the spare parts to replace it but i was hoping that i could
do it myself, does anyone hafe idotproof guide to change it, it cant be
that hard, right :\
With regard Illugi, proud owner of mk1 vrs 01
ps. i hope that my writing english is readable :)
Have you ever changed disc brake pads before? If so, the only "gotcha" is that you need a proper caliper windback tool because the Octy uses the rear discs for the handbrake function, so the pistons don't just push back into the calipers.
Your English is very good; my only note would be that the personal pronoun "i" should be the upper case "I". (Mods please note; I only said this because I thought the guy would appreciate knowing)
Thanks "I" will keep that in mind :)
I have decided to hand this problem over to a more experienced friend.
Then i will observe closely and learn how to.
But thanks anyway :)
anyone know if the Elegance 1.8t needs the same windback tool?
Any particular type, or a link please?
Same tool will be required. An old thread pop up about this a few days ago.... I'll see if I can find a link.
and to save anyone the hassle of reading any more than necessary, you need this,universally agreed as the best tool of it's type for the job
http://www.amazon.co.uk/Laser-Brake-Caliper-Piston-Re-wind/dp/B002V72SHS/ref=sr_1_1?ie=UTF8&qid=1314127288&sr=8-1
I bought one, not used it yet, but annoyingly I didn't even think of looking on Amazon, where it's under £15....I paid £18 for one off ebay, pah
Edited by Jonathan_1.8T
Jonathan
Where are you based? I have one you can borrow if you happen to be local (ish)
Scratch that, just saw you've bought one :doh:
Martin
