Swing radio bug(gered)?!
After the passanger and I accidently pressed two preset buttons (to change channel) simultaneously, the radio requires a very long press and hold on any button to switch any option, and now doesn't shut down when the key is removed from ignition! (Obviously, prior to this, a light touch of any button brought the response.) Is its brain fizzled? Any comments or suggestions will be gratefully read (there's no reset option to sort the software in the manual). Perhaps our channel buttons pushing was just coincidental?
Edited by Mafuta
Try removing the fuse under the bonnet for a 'reset'. That worked for me when my Bolero became slow and unresponsive. :yes:
Check the manual to see which fine to 'pull'
Check the manual to see which fine to 'pill'
thank you
thank you
Oh, and in my reply I meant 'pull' NOT 'pill'. That was a typo error emoticon-0120-doh.gif
