GSM3 rSAP with Nokia 6303ci - phonebook not remembered
After 2 years of fault free use of Nokia 6300 with my Bolero/GSM3 kit, I was given a 6303ci. I put in my old SIM and it connects happily - handset goes into remote SIM mode and
GSM3 downloads the phonebook OK but it does not remember the phonebook. As soon as I move away from the phonebook list page in the maxidot display, and go back, it is empty.
In fact it shows [-1] entries! It all works fine apart from that. I deleted the profile and started again - same problem.
Deleted profile again and put sim back in my old phone - works perfectly and remembers phonebook fine, so seems to be an issue with the phone.
Anyone come across this and found out how to fix it? It seems quite bizarre. I can't see anything obviously amiss in phone bluetooth settings - I guess
there cant be much wrong as it connects and works.
Thanks in advance for any guidance - I see that others have got the 6303 working Ok but with a Columbus system - should the audio part make a difference ?
Edited by Chocaholic
I see the 6303 has up to 2000 contacts storable (I use only 139) - could that be upsetting the GSM system which i think only supports 1000 ?
Even if I only use <200 of the possible contacts ?
