Door card rattle
Hi for the last couple of days the passenger side door has been rattling like h£ll, it's in the black plastic bit of the door at the bottom, were you put your cr@p in umbrella and stuff, how do I stop it? , may have to remove and put some packing or something any ideas? ;)
Please tell me a word like "hell" isn't taboo on this site.
OH NO! lock your doors and windows the forum hit squad will be knocking down your door tonight, you said the H word !!! ;)
a tiny bit of deadener helped on mine
Deadener ?? Have not a clue any links or vids
sound deadener used to 'deaden' car panels. popular brands include dynamat (expensive stuff), silent coat (does the jon just as good) and many other brands. just get a couple of sheets per door should be enough to stop the rattle.
cheaper alternative, carpet undelay might work, just cut out and stick onto the rattling area.
also a place in here http://www.build.co.uk/company_409669.htm but need to give ring before going
i've got this stuff myself http://www.ebay.co.uk/itm/Silent-Coat-40-Sheet-Bulk-Pack-Sound-Deadening-Mat-/350475891501?pt=UK_In_Car_Technology&hash=item5199fdb32d free delivery
works out only about £2 per sheet
can do all doors, boot, roof and give a nice luxury car style clunk when closing doors
Edited by fabia55
Thanx but it's not a noise problem it a rattle think it's the plastic vibrating on the metal door frame , I think if I put some single sticky foam on the frame first, it's just a little loose and when the engine is running makes the card vibrate
it will stop the rattle, what do you mean, rattle = vibration = noise
check the clips also incase any are broken/loose.
Are the clips at the bottom of the platic tray?, drivers door is fine, I will have a look when the weathers better just annoying when your driving
the clips hold the door card to the metal door, you'll need a torx screw to undo the screws
to remove the door card, u need to remove the door handle trim, there are 2 big torx screws in the handle and a few (3 If i remember) on the bottom
it will seem impossible to come off, but give it a lot of force and not worry about breaking the clips, very scary at first as u think the clips are gonna break.
then there a cable that attaches to the electric window switch, just unplug it, then lift the whole door card off, lift up first, you'll see.
Fabia55 just seen the video sorry is it you doing the ninja stuff? ;) that stuff looks good how do you attach it to the card never done anything like that before
what ninja stuff, that video isn't me. well the stuff i'm using, is really simple, just peel and stick on. i've already put a tiny bit on the roof above the the sun visors are so you don't get as much echo when you close/put the sun visors..i mean flip the sun visors back uyo.
The video here the ninja at the end just thought it was you
wish i was, double the age
.+1 ;)
