Secondary boot bag hook?
I have emailed James at Allams to see if there is a new code B)
its £7 from dealer £6.44 with discount part number DMA610007 but they want £3 postage http://www.skodaparts.com/checkout
if you have to travel a few miles for it, it will might be cheaper delivered
Yup got mine ordered! Should get them tomorrow.
Fitted the LED interior light, pictures dont do it justices, it looks amazing best mod for under £10, it looks so cool
Do you mean ordered a second hook? I thought the Elegance got two as standard? Mine has anyway :)
Well I've got the boot hook (which is excellent), but I can seem to get it fitted! Is there a guide to fitting it on here? :)
The screwholes are pre drilled, but they may have plastic caps over them. Pull them off and screw in! The holes in the trim might not match exactly so move it around until you can see the holes in the bodywork.
Slightly OT but I picked up a bag hook for £2 from Asda this morning. It clips onto the front seat head-rest (on one of the vertical metal shafts) and has two hooks. Supports upto 10kg (or is it 10lbs? Can't recall)
I also have the second boot hook in my Octy hatchback and I use them for stopping the shopping rolling about by hooking the carrier bags over them. It's as if they were designed for it ;)
This morning's purchase was to save mucking about opening the boot when I've popped down to the takeaway.
Yeah the holes in the trim don't match, but I can't even see one of the holes, let alone move the trim around to find it. Am I doing something wrong?! I spent about 20 mins trying to do it earlier before I gave up!
