FOUND THIS :)
Hello people.
Looking at fitting OCC to my octy vrs mk1. Was going to get one from Saikou Michi as it needs to be 19mm but just spotted this on awesome website.
http://www.awesome-gti.co.uk/product.php?xProd=40597&xSec=1860
Would it work? preffer to get one from uk if possible. am i right in thinking 3/4" is 19mm too??
cheers
IT should be fine if it fits the mk4 platform. Its just not a michi though ;)
Like that one actually and Draft 42 make good products.
Yeah looks ok to me too. Just wanted to double check. Prob go with this option. Have some oil resistant hose and t-pieces etc ready just need to pull finger out and pay for a can lol
Cheers guys!:thumbup:
you need to ask them 1 question
1. what internal baffeling has it got?
if answer is
yes . then its a good buy
no . no point buying as it dont do anything just looks shinney
the Saikou Michi has a very good internal baffle system to remove oil from the vapour thus its used by many as it actually works unlike most on the market!!!
remeber to get one with 19mm inlet and outlet pipes
if answer is
yeah think it has, " Inside, four filter screens create a maze for the PCV gases to navigate allowing oil droplets to collect as lighter gases pass."
"As PCV gases enter our catch can they disperse and turn upwards, forced to flow through a series of four filter screens. As the gases flow through these screens, heavy oil and gunk sticks and lighter gases reach the outlet tube at the top. Accumulated oil and gunk naturally runs off the filter screens and collect at the bottom of the tank. Without these screens, only a fraction of the liquids are trapped by the catch can. Our inlet and outlet fittings are made from ¾†tubing, the same basic size as the OEM PCV fittings and hoses."
Also is 19mm
"Our inlet and outlet fittings are made from ¾†tubing, the same basic size as the OEM PCV fittings and hoses. ":thumbup:
"As PCV gases enter our catch can they disperse and turn upwards, forced to flow through a series of four filter screens. As the gases flow through these screens, heavy oil and gunk sticks and lighter gases reach the outlet tube at the top. Accumulated oil and gunk naturally runs off the filter screens and collect at the bottom of the tank. Without these screens, only a fraction of the liquids are trapped by the catch can. Our inlet and outlet fittings are made from ¾” tubing, the same basic size as the OEM PCV fittings and hoses."
Also is 19mm
"Our inlet and outlet fittings are made from ¾” tubing, the same basic size as the OEM PCV fittings and hoses. ":thumbup:
perfect makes sense to buy that then and it looks good too.;-)
yeah thought so.
Cheers guys, just wait until founds available i guess. House move going downat the min which means less founds for car :thumbdown:
