Octavia Pd Fuel Pump Safety Recall
Had a letter this week adviseing me to call dealer and book in for safety check on bolts for Fuel pump , contacted dealer ,they did not seem aware . Have booked it in for latter next week , on 54 reg and only 6 months old . Has any one else had one of these recall lett . Is it only the 130 PD Octy .with this fault. :confused:
This recall has been in place for a while now - suprised they don't know about it.
very straightforward check - not likely to need anything.
The recall came out in December. I had my car checked and the bolts replaced between Christmas and New Year but have not had a letter about it yet.
I've also noticed it took until 17th February for it to appear on the VOSA recalls database. Honestly, I thought it hadn't appeared but decided to check while typing this in case I got it wrong!
How did I hear about the recall? BRISKODA!
It's this type of information sharing that makes this community work :thumbup:
EDIT TO ADD:
Link to VOSA database for recall information.
In case the link doesn't work here's the details.
Numbers Involved : 5000
Build Start Date : 01/03/2004
Build End Date : 31/08/2004
Details
Concern : BOLTS OF THE TANDEM FUEL PUMP COVER MAY BREAK
Description : It is advised that, on some vehicles fitted with a 3 and 4 cylinder pump injector engine, the bolts of the tandem fuel pump cover may break due to a bolt production fault. As a result, the pump housing will not be tight, and a diesel fuel leak may occur.
Remedial Action : Recalled vehicles will have the pump checked for being of a certain manufacture. If found to be within the affected range, the pump housing cover bolts will be replaced.
