1.9 SDI Classic Fusebox Layout
I am new to the Forum but have seen a web link to "Fusebox Layout" - but it is not the same as mine.
The Owners Manual doesn't match either. After blowing the Cigarette Lighter fuse, I fixed it by checking each fuse until I found the one blown.
Now they are all checked and OK but there are some unfilled places - could one of these be for the Rear Window Demister?
My SDI is a "no frills" version from 2003 and I suspect it was a taxi for its first three years.
Thanks for any forthcoming help.
my last two octavias done that the last one i had was a TDI on 55 plate and the one before that was an SDI ona 51 plate the cars done that twice i think
Does the light come on when you press the demister switch. If so it's getting power so it's not a fuse. If not you need to check F26 which is 25A. Another common cause are the connections to the heated rear window itself.
The fuse box is a mirror image of the layout in the manual
see http://briskoda.net/forums/topic/175843-fuse-panel-layout/
It turned out to be the heater connections. I believe there is some sort of conductive epoxy that can be used to fix it. - thanks for your help.
