Instrument cluster/pod
Hi a little help needed I have my 4 digit code will this let me recode a second hand instrument cluster/pod with VCDS Lite full
VCDS-Lite Windows Based VAG/VAS Emulator Version: Release 1.0 www.Ross-Tech.com
Workshop Code: 000 00000
Self-Diagnosis Log Sunday, 11 September 2011, 17:11:12:0
VIN Number: TMBNB46Y6Y3069466
License Plate: Mileage: Repair Order:
Chassis Type: 6Y - Skoda Fabia I Scan:
01,02,03,08,09,15,17,19,25,37,44,46,55,56,76
Address 01: Engine Labels: Redir Fail!
Controller: 047 906 033 A
Component: 1,4l SIMOS3PA 00HSSJ48
Coding: 00061
Shop #: WSC 13765
TMBNB46Y6Y3069466 SKZ7Z0Y0548575
5 Faults Found: 17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-00 - -16556 - Fuel Trim; Bank 1: System Too Rich
P0172 - 35-10 - - - Intermittent 17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - - Intermittent 16825 - EVAP Emission Control Sys: Incorrect Flow
P0441 - 35-00 - -16845 - Fuel Level Sensor Circuit: Implausible Signal
P0461 - 35-10 - - - Intermittent Readiness: 0010 0001
Address 08: Auto HVAC Labels: 6Q0-820-045.LBL
Controller: 6Y0 820 045
Component: Klimaanlage X0760
2 Faults Found:
00818 - Sensor for Evaporator Outlet Temperature (G263)
30-00 - Open or Short to Plus
00819 - High Pressure Sensor (G65)
07-00 - Signal too Low
Address 09: Cent. Elect. Labels: 6Qx-937-049-B.LBL
Controller: 6Q1 937 049
Component: BORDNETZ-SG.
1S30 Coding: 09370
Shop #: WSC 13765
No fault code found.
Address 15: Airbags Labels: 6Q0-909-605-VW5.LBL
Controller: 6Q0 909 605 H
Component: 04 AIRBAG VW5
0004 Coding: 12340
Shop #: WSC 13765
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: Redir Fail!
Controller: 6Y2 919 880 Cu
Component: KOMBIINSTRUMENT VDO V06
Coding: 16441
Shop #: WSC 20029 TMBNB46Y6Y3069466 SKZ7Z0Y0548575
2 Faults Found: 01128
Immobilizer Pickup Coil (D2)
01176 - Key
Address 19: CAN Gateway Labels: 6N0-909-901-19.LBL
Controller: 6N0 909 901
Component: Gateway K<->CAN 1S30
Coding: 00012
Shop #: WSC 13765
Address 25: Immobilizer Labels: None
Controller: Bit teA dre ssu
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 44: Steering Assist Labels: 6Q0-423-156.LBL
Controller: 6Q0 423 156 E
Component: Lenkhilfe 0001
Coding: 00110
Shop #: WSC 00000
Address 46: Central Conv. Labels: 6Q0-959-433.LBL
Controller: 6Q0 959 433 A Component: 0D Komfortgerát
0002 Coding: 00067
Shop #: WSC 13765
End
Edited by fig1
