Removing Elegance fog/drl unit?
Hi folks,
I've searched the glovebox manual and the forum archives, but can't see the answer to this... I want to remove the n/s front foglight/drl unit to access the squeaker (sorry "horn"). The Elegance has a full width unit in that hole in the front valance, not a lens unit with a grille piece next to it, and I can't see how to remove it. Anyone know?
Hi folks,
At either end of the lower grill there is a removable section. The vertical clips around a metal strip behind. Remove this. Put your hand in the hole and reach around the back of the lamp unit. You will feel a tab that you push that releases the light unit.
Thanks Fatbloke, success!
