312mm brakes - which discs
I'm looking for some discs for my new calipers and need some help please. I know the diameter of the discs should be 312mm, but what is the thickness I need (hub +disc I think), and what is the centre hole diameter? Hope this makes sense!
Just get some for a octavia vrs
Matt
Any recommendation on pads matt?
I've had a set of Mintex M1144 Pads on for a while, they are damn good and have lasted ages. Not cheap though.
The part number I was given by Garry at motorsportworld was MDB1531M1144 but I'd check that against the rest of your 312 brake system with him before ordering just incase.
http://www.motorsportworld.co.uk/framefix.asp?productcode=MDB2677M1144&PID=1150415
When I got my 312's (years ago now from golfturbo on here) I had zimmerman drilled discs but I can't for the life of me remember anything else about them so if anyone does know please enlighten me as I'll need a new set soon. :)
Edited by jifster
http://www.ebay.co.uk/itm/Gen-PAGID-VW-Golf-MK4-TT-front-Brake-Discs-and-pads-NEW-/160508563867?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item255f0e519b
I decided on these in the end.
OE quality.
Matched disc and pad set.
Added bonus of being painted so will take longer to
rust :thumbup:
Perfectly sufficient to do the job. :yes:
They do seem to have gone up since I bought mine (Fairly recently)
but I made an offer of £80 and it was accepted. ;) but they were only £89
when I bought them. So I got mine delivered for £87.99 all in.
Not a bad price when you consider they are supplied with genuine Pagid pads.
OEM discs and DS2500 pads are the best setup (In my opinion, of course).
I`m not much of a hard driver so i`m sure some of the other recommendations are good options. Since the fabia is massively over-braked with the 312`s I`v got some cheapy (but still known brand) pads and discs.
Matt
oem vented and ds2500 is where its at :)
Matt
Was looking at these but found out theyre the wrong size.
MK1 Octavias, MK2 is 5x112
Matt
