DIY resetting
hi everyone,just wanna ask how to reset the service indicator for mk1 octy?any ideas are much appreciated..cheers guys..
It's in the manual :
Resetting Service Interval Display
It is only possible to reset the Service Interval Display, if a service message or at least
a pre-warning is shown on the display of the instrument cluster.
We recommend having this resetting performed by a specialist garage.
The specialist garage:
• resets the memory of the display after the appropriate inspection;
• makes an entry in the Service schedule;
• affix the sticker with the entry of the following service interval to the side of the
dash panel on the driver's side.
The service interval display can also be reset with the reset button as follows
• Press the reset button with the ignition switched off and and hold it down.
• Switch the ignition on, release the reset button. The text Service or SERVICE
NOW appears in the display.
• Turn the button for setting the clock to the right - as a result of this the display is reset
:D
