R32 23mm FARB fitting
So got a new R32 Front ARB coming, to complement the rear 25mm.
What do I need to fit it. Is it just the 2x bushes, or do I need brackets as well? and will it fit the existing droplinks?
any recommendations appreciated
I have a pair of new brackets bought in error if you need some - pm me if interested
Hi, The brackets can be re used as it is only the bushes that are different thickness. But if it was me and the bracket and bolts are the original items i would replace them for the cost they are.
If you are fitting the ARB yourself a tip would be to use a longer bolt first on the bushes to compress them and bracket together and then remove bolt and fit correct size one. This is because the std bolt is short and hard to get thread started in the bracket and compress bushes at the same time.
Ok FARB arrived.
So which Bushes. VW powerflex (not keen coz of color!) or possibly Red to match neuspeed rear bushes?
any recommendations.
Ok FARB arrived.
23mm SuperPro's
Steve
