Fabia VRS bumper removal
Hi all, I'm getting my new VRS this week an need to know if it's a big job to remove the front bumper as I'm changing the headlights to black ones, has any one done it?
Hi and welcome.
Use Search as I am sure there is a thread on bumper removal.
Good Luck.
Cheers mate!
I can't find anything regarding the 11MY
Edited by H17YD_L
If its not under bumper, then it should be under DRL's or similar as the question was asked and one of the threads was showing a bumper removal. Didnt mean to send you on a wild goose chase.
I may take a bit of searching but I would estimate its within the last 30 or so days.
Hope this helps.
Will the dealer not put them on for you as a gesture of good will?
No they wont, they said the grill is £70, lights £100 each and they'll supply and fit all for £350.
So I'm gunna leave the lights for now till I've got the car so i can see for myself how easy it's gunna be, Just get the grill and fit it myself
Ahhh ok, i shouldn't think it will be too diffcult, without looking I'd think 4 screws in the engine bay, a few in the arches and a couple underneath :thumbup:
Cheers mate, I'll have a look wen I get it, normally they are easy but didn't want to buy them without knowing if it was a big job
My friend removed the front bumper of my vrs,I watched.
Mixture of screws and pins in the engine bay
same below the bumper
Screws in the wheel arch
Think you have to remove the trim around the DRLs to find two more screws
Pull back the wheel arch cover and there is another screw there
Took about 40 minutes
