Bit of help required
I dont know if i have posted this in the right area but if i am wrong please feel free to move it.
I,m having a struggle getting my sidelight bulbs out, any got any tips on how the little buggers out.
Much appreciated
John
Hi hope this helps. front wheel off or turn full lock undo all screws inner arch (plastic) or enough to get hand in pull away from wing place hand behind wing and press two tabs on light and push out replace bulb
So there is no way of doing it for the top ?
you do mean the side repeaters on the wing
No sorry, should of made it more clear. Emm when you put on your sidelights and you have the 2 lights on your headlights. Its them i wish to change
yes from inside bonnet remove headlight cover on the back of lights you will see the bulbs to change twist holder and remove if you have got owners manual tells you in there with pictures
thanks guys
thanks guys
Hand on and jiggle it about no twist just a pull but don't pull on the wires, it's a bit of a phaff
Thanks mate. They seems to be a bit tough just to jiggle and pull
