Remote Antenna wire
ware dose the blue wire go on Autoleads PC5-137 aerial adaptor if that make any sence
I believe it needs to go to a +ve 12 volt supply to power the aerial amplifier inside the aluminium tube.Normally it connects to a radio aerial supply connection ,which supplies 12v only when radio is switched on.This is to save draining the car battery if the car is not used for a long period. I think if its a Skoda radio,the radio power is disconnected ,about 2 hours after the ignition is switched off,also to save draining the battery. Although the power taken is quite small,it adds up over a period of time.
i realy need a iso wireing diagram for octy 2 :wall: :wall:
