Rear interior lights wont go off
a guy i work with has an octy vrs on a 56 plate. he bought the LED replacement lights for the interior and when fitted and car unlocked the light in the back wont go off. the front light dims and goes off with the door closed as usual but the rear doesnt, even if the key is in the ignition and engine on. when locked it goes off. hes tried the other bulb that he knows works in the front in the back and it does the same thing. also the original bulb was re tried and that works as it should. any ideas??????
Hi,
If fitting LED's they need to be CAN compattable, that is they have a smsll inbuilt reisitor fitted which will cure the problem.
Tony
surely though the same would happen to the light thats in the front? and if one was CAN compatible and the other not wouldnt it throw up a dash light? and why is it only in the back that both lights do this when tried in there?
