REMOVED MAP SENSOR - now what?
the 1.4 8v mpi has been getting very sluggish of late and even cut out on me altogether approaching a roundabout last week.
Trawling around here it would appear to be a common enough occurence, with the TB and MAP sensor being usual culprits.
Got underneath the bonnet and disconnected MAP Sensor and gave the TB a lick and a promise and added a bottle of REDDEX to the fuel tank
Car appears to be running much better/smoother now. Quite peky even.
So assuming most likely the MAP sensor was faulty - but given 'performance' seems drastically impproved with it disconnected - is it worth me replacing it with a new one, or just leave it unconnected?
And also if i want to remove the TB and give it a proper clean is that a new gasket job - if so where can i get one? I did a quick ebay search but couldnt find anything.
Any help would be appreciated.
thanks in advance
Neil
Surely if you've disconnected the MAP... You're running with an engine light on?
I would have thought that not having the map in there would result in over-fuelling at least...
As for the TB, as long as the gasket that comes off isn't torn it can be re-used. Hell, even if you traced the original gasket and cut it out on a bit of card/thick paper it'd probably do the same job - it's not operating under major atmospheric pressures so as long as the TB is tightened down well enough it'll be fine.
Edited by Chris Coates
thanks Chris
thought it couldnt be as simple as that - better reconnect it for the time being and get a new one
ta
neil
