Exhaust tip for the current ' little un'
I have twin pipes (on my diesel) but do like that! :thumbup:
Has anybody fitted this? 1.2 TSi changed from the original's twin exhausts to a single one a while back and noticed that this is now available for current models.
http://www.superskod...al-Skoda-Autoas
Still contemplating this accessory. Does anyone know how the Superskoda ones actually fit - are they via ring clamp, grub bolt or........ ?
I have two in a box and have yet to fit them since you have to cut the tail pipes to be straight and to not have the 45 degree angle they have now. You then just slip the tips over and they just clamp onto the exhaust (there are four clamps on each tip). No bolts or anything required.
Cheers for that, non too keen on cutting the tail pipe though. Was hoping for the easy life, a straight slip on and fix. Guess that's why you still have two in a box ?
Yep, that is exactly why. You have to drop the exhaust and or somehow protect the bumper (or take it off!) when you grind the pipe ends off. Hence I've not had the courage to do it yet.
Thanks once again, I've now ceased contemplating :clap:
