Vag-Com = Fault codes?
Just had a go with my laptop, a super cheap OBD-II cable and VAG-COM software.
Auto-scanned my Fabia 2 (HTP70) no problem at all.
I have two fault codes as a result:
Chassis Type: 6Y - Skoda Fabia
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 01 -------------------------------------------------------
Controller: 03E 906 023 B
Component: SIMOS91 1.2l 4V 1891
Coding: 0000071
Shop #: WSC 13765
No fault code found.
Readiness: N/A
Address 03 -------------------------------------------------------
Controller: 6R0 907 379 C
Component: ABS 8.0 front H05 0002
Coding: 0002100
Shop #: WSC 13765
Address 08 -------------------------------------------------------
Controller: 5J0 820 045
Component: Klimaanlage X0850
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 F
Component: 0000 BN-SG. 2S36
Coding: 25742
Shop #: WSC 13765
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 5J0 920 910 B
Component: KOMBIINSTR. V2823466
Coding: 17403
Shop #: WSC 13765
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
30-00 - Open or Short to B+
Address 19 -------------------------------------------------------
Controller: 6N0 909 901
Component: 000E GATEWAY CAN 2S36
Coding: 00014
Shop #: WSC 13765
Address 44 -------------------------------------------------------
Controller: 6Q0 423 156 AB
Component: LenkhilfeTRW V270
Coding: 10140
Shop #: WSC 13765
Address 46 -------------------------------------------------------
Controller: 5J0 959 433 A
Component: 03 Komfortgerát 0001
Coding: 00018
Shop #: WSC 13765
1 Fault Found:
01135 - Interior Monitoring Sensors
36-10 - Open Circuit - Intermittent
Address 56 -------------------------------------------------------
Controller:
The first (Address 17) is my outside air temperature sensor not working, which I'm already aware of and really don't care about.
The second is interior monitoring sensors (Address 46) I had my drivers door open while doing this...is this likely to be the cause?
As you say this should be the door switch open.
It should tell you how many occurrences?.......
I'll do the test again with the door closed.
Anyone know anything else useful I can use vag-com for? its all new to me :)
You might struggle to get the long coding helper up with the copy you have (same as me)
If you can get access you can enable:-
Coming home/Leaving home lights
Alarm Chirp for Lock/Unlock
Large Speedo in MFD and remove Kph
Unlock all doors 1 button press
Anti Hijack on setting away
Coming home/Leaving home lights - would love instructions for this?
Alarm Chirp for Lock/Unlock - would love instructions for this?
Large Speedo in MFD and remove Kph - I have no idea what you mean here!
Unlock all doors 1 button press - just did this myself :)
Anti Hijack on setting away - I dont know what this is, but it seems a popular feature to turn on? What's it do exactly?
Edited by MiNiMaL_FuSS
