no longer gettin spray noise when ignition turned on
Serviced my car yesterday, new fuel filter fitted too. Im no longer gettin that spray noise when you first turn on the ignition? Runs great now, k+n was caked in muck so wacked a normal filter in for the time bein.
Keep the normal filter, having seen the damage done to a turbo by poor filtration I pulled my K&N straight off. The spray noise only happens when you have less than half a tank of fuel, presumably due to slightly lower pressure. If it doesn't happen I wouldn't worry about it.
It used to happen all the time before? Yeah think ill keep the standard filter
fuel pump?
Everythins running fine, starts same too
It only makes that noise when you have half a tank.
Nope seems to do it when it wants to.
Not sure about half tank, I'm sure mine does it all the time?!
Yeah mine used to do I. All the time
