Headlight Adjuster
My headlight adjuster has never worked as far as I know. I used to think it adjusted the high beam but I think I just imagined it. People keep talking about the motor and switching it over to the new headlights but I can't see any motor on my original OEM headlights? Did some Fabia's not have headlight adjusting or something?
On my Depo's there's 2 screws on the top to manually adjust them.
How would I resolve this? I want my new Xenon headlights to be adjustable from within the car. :(
Alot of replacement headlamps do not come with the adjusting motor, so it's a case of when changing the headlamp, swap the motor over. The wiring for it should be in the headlamp, a small black rectangular connector. The motor is more or less is a black plastic square box, held in with a couple of screws, undo the screws and slide the ball out of the socket to remove it.
The motors are available from Skoda and I think are in the region of £25.
