Anyone in NW with vagcom?
If anyone has vagcom in the Norf west can they contact me please... i have a lil issue with my car id like to look at on vagccom before it goes to the dealer :(
Clarify NW.......what is your position :confused:
Im norf manchester :)
I'm North Cumbria......Vag Com is on laptop and I am still trying to figure out how it works.....
maybe someone closer?
Nero
Im also North Manchester Middleton area
Nero
I know he's impatient, but didn't think he was burning :rofl::rolleyes:
Well, thanks to Doug (Dougal) ive now got some fault codes for why my car is being a barsteward to me :o
1 Fault Found:
17964 - Charge Pressure Control: Negative Deviation
P1556 - 35-10 - - - Intermittent
Basically, it could be a number of things.. but NOT overboosting (that makes positive deviation)
things that have been suggested:
N75 valve
boost leak
faulty map sensor
VNT mechanism failure - scary :eek:
it only does it once in the morning, before the engine is fully warmed up.. and im cruising at about 70-80 mph in 5th, engine speed is around 2k-2.5k and im only using light throttle... the car will go limp and the usual engine off and restart will cure it..
any ideas?
