Led lights
Hi this prob a silly question if I change the reg plate lights to LEDs will this work fine meaning no sighns on control panel. And also can you fit LEDs to the other bulbs like the indicators and brake lights.
U need error cancelling ones, canbus friendly
Change both my fabias with LEDs number plate all interior and sidelights also done the drls in the new fabia all good done the reverse but not worth doing the indicators or brake as apparently they are not great
Oh no you don't , the interior and number plate don't need special canbus ones, although the drls and tail lights require error free ones ;)
Any recomdations on led number plates ones
eBay I have used the heat resistor ones, the ones with the metal ridges on the back, loads on eBay have a look I used HQ lighting really good quality ;)
Used Ebay for my interior ones, no problems to date.
Presume the number plates would be the same, although have not bothered to change mine, nor the boot light
Mine needed resistors for the number plates to stop canbus errors.
Maybe different for non vRS models like seb says?
Well worth doing though :thumbup:
Are the number plate bulbs 36mm or 38mm?
36 mm I think can't remember I think mine had the resistors though
Im not too sure come to think of it either...
I remember them being TIGHT though :rofl:
Were can I get the tool to remove the screws to replace the bulbs
It's a torx screwdriver you need ebay
oh yes you do! Number plate ones are in the canbus system to check if one is out as its an offence to have a bulb out there just like it is with a headlight or brake light
Sooooory :( I did get canbus error free ones with resistor, need to check before putting brain in gear, only interior is ok ;)
It all went a bit pantomime there :D
It's behind you !
just fitted 36mm canbus leds for number plates.. worked like a charm.. 2min job tops.
If you want to change the brake lights and/or indicators.. be careful.. some led bulbs do not fit in the lamp housing, they are about 1mm too wide.
I have fitted the led number plate lights now they working and can't wait to see it at night will be the dogs balls set the car off a lot. :rofl:
Do the interior cabin lights awesome
Think will take one step at a time lol not to good at doing mods myself and I rather like the green lights inside
The cabin lights they are easy 2 push in 5w and one similar to number plate no error free ones required cost pennies ;) and they look awesome
Silly question were is the builbs to do this
Your map and centre light above the mirror, you'll have 3 bulbs in there 2 maps which are push in type and the middle one which is similar to the plate lights, get them from eBay cheap as chips ;)
